The Half Doors are constructed from paintable impact resistant thermoplastic outer door skins mounted to rigid powder coated internal steel door frames. The Half Doors interchange easily with the factory steel doors and require no body modification for installation. They feature lockable door handles an internal storage pouch waterproof seals OE style hinges and mirror mounts. The Half Doors are also available with optional upper soft doors.Impact resistant thermoplastic black ABS material with enhanced UV protection.Matte finish is easily paintable for custom match factory look.Specially reinforced internal steel frame provides strength and is powder coated to resist corrosion.The textured inner ABS panels provided a finished look and feature a grab handle and storage pocket.Each door has a weather tight seal to keep out moisture and reduce wind noise.OE Style Hinges provide a factory look and are designed to last.Durable and lockable paddle handle.Matching soft upper doors available for all season protection from the weather.Designed to work with your original mirror or Rugged Ridge replacement mirrors.TThis pair of black diamond upper soft doors fit Rugged Ridge's rear half doors for 07-13 Jeep Wranglers.
Features
