This factory-style soft top from Rugged Ridge comes with door skins and clear windows. Fits 88-95 Jeep Wrangler (YJ). All Rugged Ridge Soft Tops feature durable vinyl coated polyester and cotton fabric and crystal clear DOT approved glass windows that will last the test of time. All sewn seams use marine grade thread to make sure it does not deteriorate or discolor in the sun. Each seam is literally "welded shut" with durable heat seal tape to keep moisture out while keeping the original look of the top intact. Attaching the Rugged Ridge Top is easy with the factory original "belt rail" attachment method; simply tuck under the rail and go! All our tops feature two choices of door options as Jeep offered the 97-06 Wrangler with upper soft doors or with full hard doors. Rugged Ridge makes a Replacement Top that fits either!.
