This 5-piece black plastic Body Armor guard kit from Rugged Ridge fits 07-14 Jeep Wrangler (JK).Get that offroad look with Rugged Ridge Body Armor. Each Body Armor piece is constructed of black diamond plate UV treated thermoplastic for the coolest toughest looking upgrade for your Jeep. Each body Armor attaches to your Jeep with ultra strong 3M tape to ensure a secure fit. Have a scratch or dent on your paint? Cover it up paint (to prevent rust) and install the Body Armor. You have now repaired and upgraded! Available in individual pieces or complete styling "kits" so you can customize the look of your Jeep the way you want.This 5-piece black plastic Body Armor guard kit from Rugged Ridge fits 07-14 Jeep Wrangler (JK).
Specification
